Just began a new job and being unable to inport my UI profile that I (thought I) had saved at the last job through Autodesk 360, I'm having to rebuild all the ribbon tabs, which involves loading menus not included with OOTB C3D 14. So, after bringing in 4 ribbon tabs (Surface, Parcel, Profile, Corridor) I now have them in the list of ribbon tabs, but there are 4 blue tabs that are exact copies of these four that I can't seem to delete. Here's the weird thing: they exist in EVERY workspace, just the one I'm using (which is a copy of the original Civil 3D default).
How do I get rid of these tabs?
Solved by bcsurvey. Go to Solution.
Nevermind. In picking one of several Ribbon tabs with the same name (for each one described above) in the default list in the CUI, I just chose the wrong one. Unchecking and choosing a "different" one worked fine, so now I just have the one normal tab and not the blue ones.
