AutoCAD Civil 3D Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
.NET on C3D 2012 SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Has anyone tried building a .NET app on C3D 2012 SP1 yet?
I'm trying, and I keep getting errors. No matter what I do, Visual Studio can't load AecXBase or AecXUIBase.
Re: .NET on C3D 2012 SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I confirmed the problem you are describing. I am using Microsoft Visual C# 2010 Express. When I create a new project and add references to AEC Base 6.7 Object Library (AecXBase) and AEC Base 6.7 Application Library (AecXUIBase) through the COM tab both references show up with a yellow exclamation icon next to them. If I try adding the AecXBase.dll and AecXUIBase.dll by using the Browse tab when adding references I get the attached error messages. I also notice that if I just try to add the AEC Base 6.7 Application Library through the COM tab that references for both dll show up with the yellow exclamations as opposed to just the AecXUIBase reference.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Workaround that SEEMS to be working so far for me..... There are 2 values that have been changed in the Registry which reference the TLB's. Looking at the same entries for 2011 and 2010, none of these differ from the original install, so I figured 2012 should be the same. After changing them, I can now build the projects without having to re-reference the libraries. And, so far, C3D2012 seems to be working without error as well.
In the Registry look for this Key:
HKEY_CLASSES_ROOT\TypeLib\{E8BEE100-BF69-431B-9153
Under this is an entry for PrimaryInteropAssemblyName and this has a value of:
Autodesk.AEC.Interop.UIBase, Version=6.7.107.0, Culture=neutral, PublicKeyToken=d672471c03b2c408
Change that 6.7.107.0 to 6.7.49.0
THere is one other key value, one or two entries from this one, that also needs to be changed. Once these 2 are corrected, all the SP1 build issues are gone for me.
Hope that helps....and doesn't hurt anything in the process.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't confirm, but my way to work with the references is different to standard, maybe this is a help for someone:
When I get a new AutoCAD/Map3D/Civil3D-version I do first create a test-project, within that I reference everything that could be referenced and against all warnings ==> I set "copy local" to TRUE and compile this project.
After that I go to the folder where the bin-output is stored and copy these files to a own structure for references. That looks about this:
INTEROPs
+--18_00
+--18_00x64
+--18_01
+--18_01x64
MGD
+--18_00
+--18_00x64
+--18_01
+--18_01x64
And under these release-directories I have splitted between AutoCAD, Map, Civil, ...
For the next projects I create with VS2010 I don't use the references to the DLLs or TLBs in the AutoCAD-directory or to the listing of what is saved in GAC, I use the *.DLLs from the MGD-folder or the *Interop.DLL from the INTEROPs-folder.
The big advantage is that whenever Autodesk modifies some function-signatures (and therefor built-numbers) between releases I don't fall into the trap. I'm always able to compile a project for 2010 with the signatures of the references of 2010.
I began with that at a version of AutoCAD where they mixed som parts in updates in the programs-shared folder, if I remember right it was 2009, when installing 2009 on a pc also having 2008 installed the 2008-libs were replaced (in 2008 there would have to load some objects with version 17.02). And then also the projects had a problem when I give the application I compiled to a user of 2008 he could not drive my app because of incompatible signatures within the referenced parts.
So since then I have saved all DLL's and INTEROPs and can also compile to AutoCAD/Map/Civil-versions that I have NOT installed. ![]()
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi All,
We have already noticed it and our engineering team is currently working towards a fix for this issue. QA team needs to test the fix before we can make it available for all. Sorry for the inconvenience. Please stay tuned.
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Has there been any resolution on this issue?
Michael J.Smith
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Jeff I found the reg fix posted on ADN. But it's good to see that you migrated the info out for others to have access to. Your efforts are very much appreciated!!!!
Gracias Amigo,
Michael J. Smith
