I'm trying to add an item (Curvetext) to the toolbox via XML Notepad 2007 which I have done and it appears in the Civil 3D toolbox but the tool won't execute in C3D and I also tried the tool directly in the Autolisp folder but still it didn't run.
(Command: (Load "C:\\AutoLisp\\Curve-TextV1-4") ; error: LOAD failed: "C:\\AutoLisp\\Curve-TextV1-4")
Loading the tool via APPLOAD works fine but I'm not expert enough to troubleshoot this one so all suggestions gratefully received.
Command: APPLOAD
CurveTextV1-4.lsp successfully loaded.
Command:
:: CurveText.lsp | Version 1.4 | © Lee Mac 2012 www.lee-mac.com ::
:: Type "CurveText" to Invoke ::
Command:
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by Jeff_M. Go to Solution.
Could it be your trusted location isn't formatted to support subfolders?
http://forums.augi.com/showthread.php?149050-TRUSTED-LOCATION
Don't think so as it is already set
Many thanks again Jeff - I couldn't see the wood for the trees...!!!!
