Is it possible to launch an xsl report from the command line or via code?
There's a command -GENERATEREPORT, but I think it only works off the current selected. I don't see a way to do this - maybe someone else will...
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
You would want to run -AeccLandXMLOut at the command line and specify the XML file location and name. I think this is the Javascript to run the xml and xsl file: http://www.w3schools.com/xsl/xsl_client.asp
