I am writing a lisp routine, only I can't find the command in AutoCAD for what I am trying to do. I want the Drawings Settings dialog box to open automatically when you start a new drawing. I can't find any other way to open it except through the toolspace palette. Does anyone know the command to open the Drawing Settings dialog box?
Solved by jrauch. Go to Solution.
Looks like you might just be using it to set coordinate? If so try this:
(defun c:PA83-SF () (setvar "CMDDIA" 0) (command "ADESETCRDSYS" "_ses" "PA83-SF" "_ex") (setvar "CMDDIA" 1) (princ))
