AutoCAD Civil 3D Customization
Distinguished Contributor
sacprasanna
Message 1 of 4 (477 Views)
Java and AutoCAD and Civil 3D
477 Views, 3 Replies
10-11-2012 11:01 PM
Hi all,
I am new to programming to AutoCAD and I want to know Is there any facility to java programming to develoip new tool in autoCAD or civil 3D.
Chamara Prasanna
AutoCAD Civil 3D 2012 SP 2
Sri Lanka
Alfred.NESWADBA
Message 2 of 4 (474 Views)
Re: Java and AutoCAD and Civil 3D
10-11-2012 11:49 PM in reply to: sacprasanna
as J# (>>>click<<<) is based on Framework, and development based on Framework is valid to create tools/applications for AutoCAD (and Civil) so J# should also work.
I never tried it, that's the reason why I wrote "should work" :smileywink:
- alfred -
Alfred NESWADBA
sacprasanna
Message 3 of 4 (470 Views)
10-12-2012 02:09 AM in reply to: Alfred.NESWADBA
Hallo alfred
Further pease explain advanteges and disadvanteges of using F# unless using C# and VB
Chamara Prasanna
Sri Lanka
Alfred.NESWADBA
Message 4 of 4 (467 Views)
10-12-2012 02:30 AM in reply to: sacprasanna
I can't. All Framework-based programming languages do have the same output (in principal). What you can do to develop applications for AutoCAD can be done with any of these languages.
Well each language has it's own advantages or disadvantages and if you ask someone using C# for years now may answer C# is better than VB.NET, if you read a book about VB.NET you may read the opposite opinion.
For me the conclusion for Framework-based development is: use the language you like/you know best.
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
