Think the subject line covers it but I'm trying to get the sag / crest high and low points of a vertical curve using C#.Net. I've drilled down to the PVIs and get the stations, starting stations, ending stations, etc but don't see option for high/low points. Any way to get this without iterating through every elevation between the start and end of a vertical curve?
Solved by Jeff_M. Go to Solution.
Thanks Jeff as always...probably should have tried that but I was certaint they would just be dumb line segments hehe
