Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How to change a surface point elevation with visual lisp
2 REPLIES 2
tcorey
1016 Views, 2 Replies
I am attempting to use lisp to change a TIN Surface point elevation using visual lisp.
I get the surface object with ename->vla-object
I retrieve the points safearray with vlax-get-property and then vlax-variant-value.
I now have a safearray from which I can extract each point's x y z using a counter.
I then thought I could use vlax-safearray-put-element to change the elevation. Debugging responds that the value has been 'put,' but I don't know how I need to figure out how to put it all back into the surface.
I notice that 'Points property of the surface object is read only. Does that mean I am spinning my wheels or is there a way to do this.
;This code evaluates surface points on Groundwater surface and changes them to equal OG surface if groundwater is higher.
(defun c:go ()
  (setq ogsrfv (vlax-ename->vla-object (car (entsel "\nSelect OG surface:")))
	gwsrfv (vlax-ename->vla-object (car (entsel "\nSelect GW surface: ")))
 ; (vlax-dump-object ogsrfv t)
 ; (vlax-dump-object gwsrfv t)
  (setq gwpts (vlax-get-property gwsrfv 'Points))
  (setq gwptsvar (vlax-variant-value gwpts))
  (setq lb (vlax-safearray-get-l-bound gwptsvar 1))
  (setq ub (vlax-safearray-get-u-bound gwptsvar 1))
  (setq ctr lb)
  (while (<= ctr ub)
    (setq p1x (vlax-safearray-get-element gwptsvar ctr))
    (setq p1y (vlax-safearray-get-element gwptsvar (+ ctr 1)))
    (setq p1z (vlax-safearray-get-element gwptsvar (+ ctr 2)))
    ;Get OG elevation
      (setq OGz (vlax-invoke-method ogsrfv 'FindElevationAtXY p1x p1y))
;if gw elevation is higher than og, modify gw to match og
    (if (> p1z ogz)
	(vlax-safearray-put-element gwptsvar (atoi (rtos (+ ctr 2) 2 0)) OGz)
      );end if
    (setq ctr (+ ctr 3))
    );end while
   (princ)
  );end defun
 I am attaching a test drawing with a couple of very simple surfaces.
Please don't tell me to go learn .net. I know it's better and Autodesk doesn't want to support vlisp for Civil 3D, but vlisp is just so convenient for us non-programmers.
Thanks in advance for any sage advice...
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
2 REPLIES 2
Jeff_M
in reply to: tcorey
Tim
Well...... I won't tell you, then, that the EditOperations are not available in the COM API but they are in the managed .NET API....
Jeff_M, also a frequent Swamper
tcorey
in reply to: Jeff_M
I figured that was the case. Dang it.
Thanks, Jeff.
Tim
Tim Corey
Redding, CA
Rail Community
