Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Getting the station and elevation from a profile view
4 REPLIES 4
614 Views, 4 Replies
I am using LISP in C3D 2012.  I am trying to get the station and elevation of a point I pick in a profile view.  I found the Method that will get that info, but I can';t seem to get the syntax right.
 This is the Method;
HRESULT FindStationAndElevationAtXY(
    [in] double X,
    [in] double Y,
    [out] double * pStation,
    [out] double * pElevation,
    [out, optional] VARIANT * pInBounds
This is the routine I am trying but not having any luck working.
(defun C:getsta ()
  (setq ProfView (vlax-ename->vla-object (car (nentsel "\nSelect Profile View "))))
  (setq pt1 (getpoint "\nSelect Point "))
  (setq pt1X (car pt1))
  (setq Pt1Y (cadr pt1))
  (setq pstation 1.0)
  (setq pelevation 1.0)
  (vlax-invoke profview 'FindStationandElevationatXY (pt1x, pt1y, pstation, pelevation))
 Can someone help me get the syntax right??  Thank you,
Dave
4 REPLIES 4
Jeff_M
(vlax-invoke profview 'FindStationandElevationatXY pt1x pt1y 'pstation 'pelevation)
On vacation and can't verify, but may need to add the optional out param as well:
(vlax-invoke profview 'FindStationandElevationatXY pt1x pt1y 'pstation 'pelevation 'inbounds)
Jeff, first of all, what are you doing checking the discussion groups when you are on vacation???
Next, thanks for the response.  I tried both variations, and other variable names.  The line seems to run with no errors, (I just get a nil as a response).  But pstation and pelevation are nil also.  Any other ideas?  Anyone else??
Dave
Jeff_M
Just killing time before heading off to the next segment of this trip. 🙂
You might try (vlax-invoke-method ....) instead of the shorter version.
Jeff, obviously, the vacation isn't dulling your brain.  Adding the -method did the trick.  Thank you, now get back ot the vacation.
Dave
Rail Community
