We've created a very in-depth HDPE catalog for C3D 2014 Pressure Pipe Networks (similar to the catalog we created for Plant 3D). It works great so far, except that we can't get the pipe to bend along Existing Grade or Design Grade surfaces. Is there a rule or setting that we're missing to allow this to happen correctly?
Thanks!
Hi Mark,
Welcome to the Autodesk Civil 3D forums! I don't have an answer for you, but I do have a suggestion. The forum you posted in is mainly for programming type questions (.NET, lisp, etc.) relating directly to the C3D API's. For all other questions, there are far more knowledgable folks over in the main C3D forum which is where I'm going to ask the Moderator to move this to. Hopefully you will get an answer or two that helps you over there.
Jeff
Hi Mark,
As Jeff indicated, please redirect / post this question to Civil 3D User Forum;
this particular forum is used for Civil 3D API / programming related questions.
