Hello, how are you?
I would like to create a new utility like this:
I would ask to the user the following data :
1)select a feature line (it would be generally the feature line cut) called in this example (cut_fl)
2)Select the factor slope.
3)select an alignment and its project profile.
4)Select the grade
Then I create 2 surfaces:
The first surface has 2 breaklines (cut_fl and a new feature line with offset of the other).
This surface would be a slope.
The second surface has 2 breaklines ( one breakline is pol3d with the geometry (alignment and profile) and the second feature line is an offset of the first one with grade).
Finally, I calculate the intersecction between 2 surfaces and create a new feature line.
I would delete all temporal surfaces and feature lines used for this case.
However I don´t know if there is a shorter method to do this.
Any ideas?
Thanks in advance.
Perhaps I could use "MinimumDistBetweenSurfaces" command because minimum distance=0 is the intersecction between both surfaces.
For example this:
