AutoCAD Civil 3D Customization
New Member
Seyyed
Message 1 of 6 (676 Views)
Extract Sampled Cross Sections into a text file
676 Views, 5 Replies
06-28-2012 01:50 AM
HI,
I want to extract sampled sections to a text file like "Station,Offset,Elevation" by C#.net
Something like tplate output in land companion,
wich functons should I have access to do above?
ADN Support Specialist
Partha.Sarkar
Message 2 of 6 (645 Views)
Re: Extract Sampled Cross Sections into a text file
07-03-2012 12:08 AM in reply to: Seyyed
Hi Seyyed,
I don't see any public function available in Civil 3d .net Section object to extract these details at the moment.
FYI - Section object is not yet fully exposed in .NET API.
Did you check the following API (Civil 3D COM ) ?
IAeccSampleLineVertex:: Location Property -> Gets or sets the 3D point location for the sample line vertex.
IAeccSection:: ElevationAt Method -> Gets the cross section elevation at a specified offset.
IAeccSection:: Station Property -> Gets the cross section station distance.
I am not familiar with 'tplate output in land companion'; if this is sampling the surface along a line, then you could see the following blog post with code sample useful to you -
Using SampleElevations() in AutoCAD Civil 3D 2013 .NET API
http://adndevblog.typepad.com/infrastructure/2012/04/using-sampleelevations-in-autocad-civil-3d-2013...
Want to use only StartPoint and EndPoint as input to .NET API SampleElevations()?
http://adndevblog.typepad.com/infrastructure/2012/04/want-to-use-only-startpoint-and-endpoint-as-inp...
Does it help ?
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Jeff_M
Message 3 of 6 (636 Views)
07-03-2012 05:10 PM in reply to: Partha.Sarkar
Partha, the template in LDT was essentailly the Assembly in C3D, so I think they want to get the design data.
Seyyed, I don't have time to test this, but it looks like you can use the .net API in 2012 & 2013 (maybe earlier versions as well, I haven't looked). You will need to get the sections via the Alignment, SampleLineGroup, SampleLine, Sections, Section, SectionPoints. The section points returns a collection Point3d object which you can then use the Alignment's StationOffset() method.
Jeff_M
Message 4 of 6 (633 Views)
07-03-2012 07:23 PM in reply to: Seyyed
Or maybe you just need to run the Corridor SectionPoints report and save it as an Excel file?
New Member
Seyyed
Message 5 of 6 (625 Views)
07-05-2012 06:31 AM in reply to: Seyyed
HI,
Thank you partha,Jeff_M
I'm starting C3D programing about two weeks.
I want ground point data, In LDT in cross section  menu we have a command that give us a file (attached.)
Because our company uses a Local software for analyzing Profiles sections and Volumes, we need to import ground sections to it.
So when we migrated to C3D I didnt have an option, then I used landXml and export the project to landxml and importing it to LDT for my purpose.
sorry for my poor english
<script id="__changoScript" type="text/javascript">// var __chd__ = {'aid':11079,'chaid':'www_objectify_ca'};(function() { var c = document.createElement('script'); c.type = 'text/javascript'; c.async = true;c.src=( 'https:' == document.location.protocol ? 'https://z': 'http://p') + '.chango.com/static/c.js'; var s = document.getElementsByTagName('script')[0];s.parentNode.insertBefore(c, s);})(); // </script>
Employee
peterfunkautodesk
Message 6 of 6 (603 Views)
07-07-2012 06:03 PM in reply to: Seyyed
I would either use the Corridor "Section Points Report" and save the results as a text file, or look at the source code for the Corridor Section Points Report's source code that ships with Civil 3D to see how we extract the data from the corridor model. If you are also looking at existing ground points, there are a bunch of examples on how to extract ground points between two points.
Peter Funk
Peter Funk
