Extract AECC_COGO_POINT information
Message 1 of 13
Hi all,
Any idea how to extract the information of "AECC_COGO_POINT" of CIVIL3D 2008 such as the x,y,z coordinates using Lisp programming.
In LDT 2005 the information can be extract using "ENTGET". Thanks.
Replies (12)
Message 2 of 13
Use the ActiveX API. In 2008 you can use normal selection methods to select
the point. In 2007 you must use the SelectPoints method of the Points
collection of the Drawing.....here's an example I made to retrieve the
elevation of points for 2007 (also works with 2008):
;;Get Point elevations....
(setq *acad* (vlax-get-acad-object))
(setq C3D (vla-getinterfaceobject *acad* "AeccXUiLand.AeccApplication.4.0"))
(setq C3Ddoc (vla-get-activedocument C3D))
(setq pnts (vlax-get C3Ddoc 'points))
;;ask to select points
(princ "\nSelect points to query the elevations of: ")
(setq selectedPnts (vlax-invoke C3Ddoc 'SelectPoints))
(foreach pnt selectedPnts
(setq elev (vlax-get (vlax-invoke pnts 'find pnt) 'elevation))
(princ (strcat "\nElevation of Pt#" (itoa pnt) " = " (rtos elev 2 2)))
Use the Easting & Northing propoerties to obtain the x/y values.
HTH,
Jeff
wrote in message news:[email protected]...
Hi all,
Message 3 of 13
Hi Jeff,
Thaks for the reply, i will try this and check the results thanks again.
Freddie
Message 4 of 13
Hi Jeff;
I have problem loading the lisp. i doesnt load (vla-getinterfaceobject*acad* "AeccXUiLand.AeccApplication.4.0"). Can you help me load the lisp program. thanks for the help.
Freddie
Message 5 of 13
If you are using 2008 then the line
needs to be
(setq C3D (vla-getinterfaceobject *acad* "AeccXUiLand.AeccApplication.5.0"))
Jon
Message 6 of 13
Hi Jon,
Thanks for the reply, also can ask how to Use the Easting & Northing properties to obtain the x/y values. thanks.
Message 7 of 13
Oops, sorry about the version thing. Thanks, Jon, for picking up on that.
This will get the XYZ values:
(setq pt (vlax-invoke pnts 'find pnt)
z (vlax-get pt 'elevation)
x (vlax-get pt 'easting)
y (vlax-get pt 'northing)
;;do whatever you want with the x y z values......
Hi Jon,
Message 8 of 13
I learned the version thing from you in the first place Jeff.
Jon
"Jeff Mishler" wrote in message
Hi Jon,
Message 9 of 13
hello,
thanks guys for your reply this is acatually what i did;
(setq elev (vlax-get (vlax-invoke pnts 'findpnt) 'elevation)
eastng (vlax-get (vlax-invoke pnts 'find pnt) 'easting)
northng (vlax-get (vlax-invoke pnts 'findpnt) 'northing)
info_line (strcat (itoa pnt) "\t" (rtos northng 2 2) "," (rtos eastng 2 2) "," (rtos elev 2 2))
(write-line info_line f)
one more question what if i want to include other informations such as Primary point group, Raw Description, Full Description etc. is it adding another setq? and also how to insert that into my info_line? another thing last time i load this routine it works properly and now i load it again, it gives me this error ;error: Civil 3D API: The parameter is incorrect.
freddie
Message was edited by: freddie.inno
Message 10 of 13
The Primary point group is a bit more complicated. Look into iterating the
PointGroups collection, finding which one(s) it belongs to, capture the
DrawPriority of the Group(s). The Primary group is the one with the lowest
number (I think).
To include the other information, just do as you've done for the NEZ.....
'rawdescription 'fulldescription
I am not sure what may be causing that error. Could you post your entire
code?
Message 11 of 13
Freddie,
One other comment I should make. While all this can be done in lisp, I think
you will find it worth your while to investigate coding in VBA. You will end
up having a much easier time trying to figure out what Objects support what
Properties & Methods. I know, I walked the on the light lisp side for quite
a while, but now I've even done some things with C#.NET that I can't even
think of trying in lisp.
Just something to ponder.....
Message 12 of 13
Hi Jeff,
Thanks for your help, actually im thinking of doing that in .NET and ofcourse, I may take some time to learn and hopefully I can be good programmer like you. thanks again.
Message 13 of 13
Another one switches from LISP!
Peter Funk
Civil 3D Product Manager
Autodesk, Inc.
