AutoCAD Civil 3D Customization
*Expert Elite*
neilyj
Message 1 of 6 (743 Views)
Export/Import Surface Analysis
743 Views, 5 Replies
09-07-2011 03:17 AM
Within the UKIE Country Kit there is a lsp that exports/imports Surface elevation Analysis data (attached lisp file)
Can someone advise if this is possible to be modified so that a Slope analysis is exported/imported and how easy/difficult it is to do (or even make the alterations themselves!!!!).
I am lisp illiterate hence the request.....
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
*Expert Elite*
Jeff_M
Message 2 of 6 (732 Views)
Re: Export/Import Surface Analysis
09-07-2011 12:16 PM in reply to: neilyj
Nope. As you can see in this image, the only 2 Analysis properties they exposed for programmer's use are Elevation and Watershed.
However, C3D2012 has a new .NET API for Surfaces that DOES allow access to all of the different Analysis types. So after a quick glance, it does appear this can be done for use with C3D 2012+, but not in lisp.
Jeff_M, also a frequent Swamper
*Expert Elite*
neilyj
Message 3 of 6 (724 Views)
09-08-2011 12:12 AM in reply to: Jeff_M
Many thanks for this - I'll just need to wait until it's part of the core product.....I feel a support request coming on.....
neilyj
Active Member
agreement
Message 4 of 6 (609 Views)
04-18-2012 06:00 AM in reply to: neilyj
Sweet !  This is exactly what I needed.  I have been using the Elevation Banding analysis display mode to create a 'weather map' version of our topo as the site contractor submitted monthly topo data to our jobsite BIM Lab.  It allowed us to show the progression of site development over time in a quick overview.
The main frustration I had was the lack of a function to export the elevation banding setup and import it into another surface file.  This lisp routine worked great !  I also like that it writes the schema to a txt file so we can have a master schema and apply it to multiple files.
Thanks for posting it.
Active Member
agreement
Message 5 of 6 (608 Views)
04-18-2012 06:05 AM in reply to: agreement
Here is an example of the weather map files we are creating.
Message 6 of 6 (174 Views)
12-09-2013 09:56 AM in reply to: agreement
Did you ever get t he route to export RGB numbers as the color?
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
