Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Exception when getting IAeccApplication after upgrading Civil3D 2014 to SP1
2 REPLIES 2
jordanmarr
410 Views, 2 Replies
I am getting the following exception when I try to instantiate an instance of the IAeccApplication after installing SP1 on Civil3D 2014:
"Unhandled Exception 6E73E188 (Access Violation Reading 0x0028) at address D330DD9Eh"
Here is the call that causes the exception:
AcadApplication acadApp = GetAcadApp();
IAeccApplication app = (IAeccApplication)acadApp.GetInterfaceObject("AeccXUiLand.AecccApplication.10.3");
Jordan
2 REPLIES 2
jordanmarr
in reply to: jordanmarr
I should also add that if I hit the OK button on the exception dialog a few times, the code will continue executing and the IAeccApplication object appears to be instantiated.
jordanmarr
I found the problem, which I will share in case anyone has a similar problem, although it is a little embarassing:  Smiley Embarassed
I was debugging by setting my UI project in Visual Studio "Start extrnal program:" to "%programfiles%\Autodesk\Autodesk AutoCAD Civil 3D 2014\acad.exe".
At some point before running and debugging my application I manually opened "Autodesk AutoCAD Civil 3D as AutoCAD 2014", which caused subsequent debug runs of my application to launch vanilla AutoCAD 2014 instead of Civil3D.  Being new to Civil3D, I did not notice the subtle difference between the "A" icon in the top left corner (Civil3D is blue while Acad is red), nor did I notice the missing C3D tool pallette.
Consequently, when I tried to netload my app, it would throw a few exceptions but would still load (partially).  Some things would work, but then others would fail.
Hopefully this will help someone (maybe me 6 months from now when I forget and stumble across my own Q/A thread).
Jordan
Rail Community
