Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Error messages when an auxiliary point is not valid in SAC
1 REPLY 1
viktors.zilinskis
358 Views, 1 Reply
Hi! I have created a custom ditch assembly. I have used auxiliary points to test different slopes and then check their existence with IsValid API function. Depending on whether these auxiliary points exist or not I choose different geometry for the ditch. There are always some auxiliary points that do not exist in any given section and I would like subassembly composer not to report it as an error. Is it possible? As it is now all the auxiliary points that are not valid are reported as an error in the Event Viewer in Civil3D (see attached image). Thanks in advance!
1 REPLY 1
Have you tried debug the code to see how your code behaves when these points are requested?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Rail Community
