Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Determining Dam Permit Volumes in Civil 3D
1 REPLY 1
dbrookshire
725 Views, 1 Reply
I am looking to find out if the is a way of generating a stage storage table or volume table showing only the volume in the pond from the lowest intersecting existing ground contour to the top of the pond (to determine what would spill out of the pond in case of a berm failure) and if Civil 3D could make the determination of where that intersecting point is.
Dave B
1 REPLY 1
Partha.Sarkar
in reply to: dbrookshire
Hi Dave B,
There is no direct way to generating the Volume table, however I think you can achieve this using the GetBoundedVolumes() and ExtractContours() .NET API.
You can get some code snippet on GetBoundedVolumes() and ExtractContours() in our Infrastructure DevBlog page (links given below) :
http://adndevblog.typepad.com/infrastructure/2012/05/using-surfacegetboundedvolumes-in-autocad-civil...
http://adndevblog.typepad.com/infrastructure/2012/08/extract-surface-contours-using-civil-3d-net-api...
Hope this helps.
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
