Good night.
Would you like a guide or manual on how to create custom reports or modify existing reports using VBA. NET or other tool.
Jhooney R. Gomes
Hi Jhooney,
if you would like to have a perfect solution to create (any) custom report, please check the link below.
There you'll find the Visual Report Designer.
The applications offered on www.civilplus.de are designed to give you the tools to unleash the true power and potential of AutoCAD® Civil 3D®.
All applications are designed to significantly increase your productivity with AutoCAD® Civil 3D®
With Visual Report Designer, you can quickly and easily create custom richly formatted reports from your AutoCAD Civil 3D data. Creating a report is as simple as dragging and dropping fields from a list. Reports may be exported to PDF, HTML, RTF, and many other formats, or may be inserted directly into your AutoCAD Civil3d drawing files.
Use Visual Report Designer to create slope stake notes, quantity takeoff reports, or most any other report or table you can imagine.
Best Regards
You can look into the source files of Civil 3D report tools and edit / further customize it. Source is available :
C:\ProgramData\Autodesk\C3D 2014\enu\Data\Reports\Net\Source
Partha
hey Partha
any follow up, ie. tutorial on these files, I assume they are dot net.
second question, is the new recommended workflow for reports leaning towards dot net instead of xsl?
