This is a question that is a little different from the ones posted on the thread.. I noticed the other day when i was converting LDD points in a file that I opened in C3D that some of the points shifted from there orig. location. This was not a shift of equal propotion.. some where a little farther away then anothers and some didn't move at all.. Is there something that I am missing in the conversion process..
Billy
I believe you will see that when the LDT drawing has a BasePoint/NorthRotation set. C3D will always use the Northing/Easting stored with the LDT point and always uses North as up. It's possible that those that "don't move" are close to the Basepoint so they won't appear to move.
I'd be happy to take a look at the file for you if you want.
