AutoCAD Civil 3D Customization
Active Contributor
viktors.zilinskis
Message 1 of 2 (443 Views)
Conditional point/link code in subassembly composer
443 Views, 1 Replies
01-10-2013 01:01 AM
Hi! I think I saw once somewhere at some blog that it is possible to define point/link codes using some conditional expressions. When I try to write in an expression under "Link Codes" I get an error. Is there a way to create conditional codes without the use of "decisons"? Any ideas would be apprecciated!
BR, Viktors
Civil3DReminders.com
Message 2 of 2 (426 Views)
Re: Conditional point/link code in subassembly composer
01-11-2013 12:21 AM in reply to: viktors.zilinskis
I think you'd need to define a variable and the use that variable as the code value. Not ideal, but it's better then managing code set styles for each of the sections.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
