AutoCAD Civil 3D Customization
Valued Contributor
raghulan
Message 1 of 2 (148 Views)
Civil3d object geometry creation
148 Views, 1 Replies
10-13-2012 09:02 PM
Hello Ppl,
 I already posted simillar question..found that there isnt api to get pipe geometry..
since we can get the pipe starting point, ending point, lendth elevation, etc. is it possible to create geometry object using this information..is there any example code on how to create geometry data type..
any help will be greatly appreciated..!!
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
Board Manager
Daniel.Du
Message 2 of 2 (120 Views)
Re: Civil3d object geometry creation
10-22-2012 08:36 PM in reply to: raghulan
At least you can use Map 3D API to create geometry if you can get the detail coordinate information of pipe. Please refer to <Map ObjectARX SDK 2013>\Map Samples\Platform\Bridge sample for demo of how to create geomtry from corrdinates.
Daniel Du
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
