• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D Customization
    raghulan
    Civil3d object geometry creation
    111 Views, 1 Replies
    10-13-2012 09:02 PM
    Hello Ppl,
     I already posted simillar question..found that there isnt api to get pipe geometry..
    since we can get the pipe starting point, ending point, lendth elevation, etc. is it possible to create geometry object using this information..is there any example code on how to create geometry data type..
    any help will be greatly appreciated..!!
    Raghulan Gowthaman Cert IV TAA, B.E,.
    Senior Civil BIM Consultant | Geo Spatial - IT Specialist
    CSI Global pty Limited. - Singapore | Sydney
    Web : www.csigs.com.au
    www.civil3dforum.com | www.e4forums.com
    Please use plain text.
    ADN Support Specialist
    Re: Civil3d object geometry creation
    10-22-2012 08:36 PM in reply to: raghulan
    At least you can use Map 3D API to create geometry if you can get the detail coordinate information of pipe. Please refer to <Map ObjectARX SDK 2013>\Map Samples\Platform\Bridge sample for demo of how to create geomtry from corrdinates.
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
