• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D Customization
    Active Contributor
    raghulan
    Civil3D pipe Road Data to SDF (GIS) Export using .NET C#
    291 Views, 9 Replies
    09-23-2012 09:58 PM
    Hello Ppl,
     I have this issue,
    I want to export civil3D pipe, road, alignment as SDF file with additional properties.
    currently civilSDF Export option only has limited options for exporting for civil 3D objects.
    Basically I am developing an app It would export selected feature(eg: pipe) with all available properties such as material, radius, etc.
    I tried an example online - which showed how to create SDF file and fetch data from layers. which is not usefull in my case.
    I want to do exactly like the civilsdf export tool with additional properties can be selected.
    if anyone help me with, how I can get geometry data of pipes or an exmple atleast that would be great.
    Thanks guys.!
    Raghulan Gowthaman Cert IV TAA, B.E,.
    Senior Civil BIM Consultant | Geo Spatial - IT Specialist
    CSI Global pty Limited. - Singapore | Sydney
    Web : www.csigs.com.au
    www.civil3dforum.com | www.e4forums.com
    Please use plain text.
    Distinguished Mentor
    Re: Civil3D pipe Road Data to SDF (GIS) Export using .NET C#
    09-24-2012 05:10 AM in reply to: raghulan
    have a look at the infrastructure dev blog here-
    http://adndevblog.typepad.com/infrastructure/
    There are a few examples of working with civil 3d objects.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    Active Contributor
    raghulan
    09-24-2012 04:49 PM in reply to: raghulan
    Thanks for the reply. but I couldnt find anything relavent to pipes in there.
    If there is any code snippet that would be great.
    Cheers
    *Expert Elite*
    09-24-2012 10:39 PM in reply to: raghulan
    Check out:
    C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Civil 3D API\DotNet\CSharp\PipeDataExcel\PipeDataExcel.cs
    Christopher
    Civil Reminders
    http://blog.civil3dreminders.com/
    http://www.CivilReminders.com/
    Active Contributor
    raghulan
    09-24-2012 11:21 PM in reply to: Civil3DReminders.com
    I cheked it but it doesnt give anywhere for getting geometry of the pipes.
    Is there any example on how to get the geometry of the pipe or create gemetry data of pipes to be stored in an SDF file from the start and end point of the point.
    Cheers
    ADN Support Specialist
    09-25-2012 01:40 AM in reply to: raghulan
    I don't see any API available to export Civil 3D objects other than using the ExportToSDF  command (Export Civil Objects to SDF).
    This UI command exports the Geometry and some other useful attributes like - InsideDia, OtsideDia, Length, slope etc.
    Once the SDF is connected using FDO provider you can use the Expression builder and use the "Geometry" property to create a custom calculation.
    Does it help ?
    Partha Sarkar
    Developer Technical Services
    Autodesk Developer Network
    Active Contributor
    raghulan
    09-26-2012 09:24 PM in reply to: raghulan
    Thank Partha for the info.
    Now I changed the course ...I am creating the SDF using the standard tool from C3D and then I wrote some code to create additional property defnitions under each featureclass..
    then another code to insert/update value to the appropriate property defnition.
    I am stuck at the point where my code to insert/ udpate doesnt seem to work.
    Is there any example for code sinpet in C# to insert/ update value to the desiered coloumn and row in a feature class.
    While inserting/ updating i want the code to choose the appropriate feature class (eg: pipe) and then column or property defnition (eg: lets say associated surface - custom added property - string data type) and check the pipe name (row) and add value.!!
    please assist.
    09-27-2012 03:32 AM in reply to: raghulan
    >>> Did you check the following blog post ?
    http://adndevblog.typepad.com/infrastructure/2012/05/how-to-modify-update-feature-attribute-using-ap...
    Does it help ?
    Partha Sarkar
    Active Contributor
    raghulan
    09-27-2012 05:36 PM in reply to: Partha.Sarkar
    Partha,
     I checked that, my code is derived from that one and other the MAP3D developer Guide example and anothero one I found from OSGEO documentation.
    But the problem is the code explains how to insert update data located in a layer.
    in my case I have a SDF file and the SDF file I have feature classes (pipes, roads, alignments, etc) with that I have property defnitions (id, radious, starting point ,etc)
    also there may be multiple pipes available (P1, P2, p3)
    Now I want to go in to the desired feature class (eg: pipe)
    then to the appropriate property defnition(eg: Associated surface - which already created in the schema)
    and then I have go the row (pipe - p2) and update the value of the Associated surface for pipe p2 to the desiered value...
    Any help would be appreciated. !!
    Active Contributor
    raghulan
    10-10-2012 10:09 PM in reply to: Partha.Sarkar
    some more information
    My schema Structure (SDF File)
    Schema name: Civil_schema
    Feature classes : Pipes, structure, point, ...
    properties inside Pipes feature class : PipeRadius, PipeType,....
    Now that I have the schema, I have two pipe data inside (two rows - PipeName = p1 and p2)
    I want to insert PipeType as Iron for R-1P1 and PVC for R-1P2
    for some reason my insert and update command isnt working...
    Code snippet
    //static sdf file
    string sdffile = "c:\test.sdf";
    //created a IConnection con (i have this in correct - just dont want to write all)
    using(con)
        using (osgeo_command.Feature.IUpdate update_data =                 con.CreateCommand(osgeo_command.CommandType.CommandType_Update) as osgeo_command.Feature.IUpdate)
                //set the target schema
                update_data.SetFeatureClassName("Civil_schema: Pipes"); //schema name:clas name = this worked for reading
                update_data.SetFilter("Name = R-1P1"); // this is to identify the row - i am not going to update this row
                // property value collection
                PropertyValueCollection pcoll = update_data.PropertyValues;
                //creating a property value that needs to be added
                 PropertyValue propvalue = null;
                 propvalue = new PropertyValue();
                 ValueExpression expression = (ValueExpression)Expression.Parse("'Iron'"); //want to add iron as my pipe type
                propvalue = new PropertyValue("Pipetype", expression);//here i am specifying the column name as Pipetype
                pcoll.Add(propvalue);
                 if (1 != update_data.Execute())
                            ed.WriteMessage("\nUpdate failed");//this writes the message in autocad
    I dont know where i am going wrong...could you guys point me the correct direction please..
