Hi all, I saw a nifty toolbar on a AUI presenters Civil 3D. He had created a toolbar that assigned his personal surface styles to a surface. After much research, I am thinking I willl need to copy and modify macros of the Edit Surface Style command. Am I on the right track and does anyone know where I can find some tutorials or references? Thanks for the info........Peace
Jethro
Probably was done with some lisp. If the class you were in was given by David Garrigues, I think that he posted the lisps in the class materials. This would give you a starting point.
Also, another David (Dave Couch) was setting up swapping label styles in much the same way. There is a thread on here discussing this and should have some code to help you: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Change-Label-Style/m-p/2532491#M3976
Thanks Jeff, yes David G was the presenter. Unfortunately he didnt get into how he created his toolbars and I looked through lisps but no luck. Maybe he will respond to my question and I will keep on searching for a solution. Thanks again
Hint: Most Civil objects have a .STYLE property or .LABELSTYLE property (string name), I have a bit of code that simply assigned the selected object to a basic acad object type... see below
Expand this code to specifiy a target style (object or label) instead of picking it...
Public Sub MatchStyle()
Dim obj As AcadObject
Dim sobj As AcadObject
Dim tobj As AcadObject
Dim slbl As AcadObject
Dim tlbl As AcadObject
Dim p1 As Variant
On Error Resume Next
ThisDrawing.Utility.GetEntity obj, p1, "Pick Source Style -> "
Do Until Err.Number <> 0
If Err.Number = 0 Then
'is this a LabelStyle or an Object Style?
If InStr(1, obj.ObjectName, "Label", vbTextCompare) > 0 Then
'select target
Set slbl = obj
ThisDrawing.Utility.GetEntity tlbl, p1, "Pick Target Label Styles to be Changed -> "
tlbl.LabelStyle = slbl.LabelStyle
Else
'select target
Set sobj = obj
ThisDrawing.Utility.GetEntity tobj, p1, "Pick Target Object Style to be Changed -> "
Set tobj.style = sobj.style
End If
End If
Loop
Err.Clear
Err.Number = 0
On Error GoTo 0
End Sub
