acrocha,
Yes I did, it is basically the same way, I wasnt looking in the right area..go figure.
Find path in registry editor: (command prompt: regedit or Run: regedit)
HKEY_LOCAL_MACHINE\SOFTWARE\AUTODESK\%VERSION%\%R%\ACAD%VERSION_SOMETHING%\AdLM\
**If you dont already know be very careful in the registry editor!
Change:
Type REG_DWORD binary data (select and rightclick Modify)- 2a (stand alone) to 19 (network)
If there are multiple servers (for distributed licensing) then go to:
My computer properties
Advanced
Environment Variables
select system variable - ADSKFLEX_LICENSE_FILE edit
add servers in sequencal pull / check order @server1;@server2;@backup
Let me know how it goes or if you get caught up on something.
Paul
Edited by: pantila on Jul 27, 2009 12:18 PM
