Can you create Catchment Objects from the API?
ralstogj
ralstogj
Hi
Can you create Catchment Objects from the API or does any one know how to update the SSA file to include your catchment data?
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Hi Justin,
From the API help file, I don't see an way to create Catchment object. However, Civil 3D .NET API Catchment class has exposed members to access some of the properties.
>>> I would suggest you to ask this in Civil 3D user group as this has nothing to do with API.
ralstogj
Partha
Seeing it in not in the managed API I have just been having a play with trying to use the send command to send CREATECATCHMENTFROMOBJECT to the command line and then passing the last object that I have set as a polyline pulled out of a parcel object.
Then I am using sendkeys to try and tab thru the dialog box but Civil3d gets the focus. Can I stop this happening or set up a hook in and event that watches for the "Create Catchment from Object dialog"" to appear to grab back the focus back along the lines of these links?
http://miamicoder.com/2008/how-to-spy-on-a-windows-program-tracking-main-window-activation/
http://through-the-interface.typepad.com/through_the_interface/2008/05/filtering-windo.html
I did do it years ago 2002-2003 in vba and by starting an external .exe watching for the window handle and name but will have to hunt down the code and expect it will not work with 64 Bit system anyway.
Any suggestions on I simpler way. The end goal I am trying to achieve is to get my parcels which represent catchments linked to structures allready (a couple of hundred) into catchments and out to SSA.
    Public Sub MakeCatchment()
        Dim document As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = document.Editor
        Dim db As Database = document.Database
        ''Select a polyline to turn into a catchment object
        Dim peo1 As New PromptEntityOptions(vbLf & "Select a Catchment Object : ")
        peo1.SetRejectMessage(vbLf & "Invalid selection...")
        peo1.AddAllowedClass(GetType(Autodesk.Civil.Land.DatabaseServices.Catchment), True)
        Dim pEntrs As PromptEntityResult = ed.GetEntity(peo1)
        If PromptStatus.OK <> pEntrs.Status Then
            Return
        Dim ParcelId As ObjectId = pEntrs.ObjectId
        Dim app As AcadApplication
        app = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
        'app.ActiveDocument.SendCommand("AddNetworkPartsToProf" & vbCr & "Select" & vbCr & "P" & vbCr & vbCr & "(handent ""faa8f"")" & vbCr)
        app.ActiveDocument.SendCommand("CREATECATCHMENTFROMOBJECT" & vbCr & "Last" & vbCr & Chr(27) & Chr(9) & Chr(9)) ''The 'chr(27)' means ESC key.
        '' 11 tab keys
        SendKeys.Send("{TAB 13}")
Regards
Justin Ralston
augusto.goncalves
Hi Justin,
I saw your comment on my blog post, but it's not there anymore...
Anyway, the thing about sending messages to Windows Dialogs is that we cannot do it from the main AutoCAD thread, like from inside a command. You need to start a second thread that will watch the dialog opened and then send keys to it.
After SendCommand, start another thread, wait until the dialog is ready, the call SendKey to it.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
ralstogj
Augusto
Do you have or could you point me in the direction of an example of how to start a second theard from in Autocad.
Justin
Regards
Justin Ralston
augusto.goncalves
Justin,
There are several samples on the web, this is a .NET feature. Try this http://stackoverflow.com/questions/10182563/create-a-new-thread-in-vb-net
Important: as AutoCAD Civil 3D is not multi-thread, we cannot directly sync back to AutoCAD. So inside the 2nd thread, you can use User32 FindWindow (http://www.pinvoke.net/default.aspx/user32.findwindow) to get the dialog, then get the Handle to SendKey.
Augusto Goncalves
ralstogj
Thanks Augusto, I will have a look into it and see if I can get something working.
Regards
Justin Ralston
