Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Can I get CogoPoint from NumberPoint or IdObject?
2 REPLIES 2
joantopo
428 Views, 2 Replies
Hi.
I´m trying to get a CogoPoint object from CogoPointCollection but I can do it.
       ObjectId Id = civDoc.CogoPoints.GetPointByPointNumber(PointNumber[k]);
 method "GetPointByPointNumber" returns ObjectId from NumberPoint.
I thought that that method returned CogoPoint.
I can do this:
 CogoPointCollection CPcoll = civDoc.CogoPoints; //colección de puntos COGO en el dibujo
 but then I have to do a loop (foreach or for..) to find CogoPoint with the same NumberPoint.
Are there any ways better?
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
zrobert
in reply to: joantopo
Hi;
You got CogoPoint Id by GetPointByPointNumber method, and then convert id to CogoPoint object
inside of transaction.
If I understand the question...
public class CogoTest
        #region Fields
        /// <summary>
        ///     The Acad document.
        /// </summary>
        private readonly Document acadDocument;
        /// <summary>
        ///     The Civil document.
        /// </summary>
        private readonly CivilDocument civilDocument;
        #endregion
        #region Constructors and Destructors
        /// <summary>
        ///     Initializes a new instance of the <see cref="CogoTest" /> class.
        /// </summary>
        public CogoTest()
            this.acadDocument = Application.DocumentManager.MdiActiveDocument;
            this.civilDocument = CivilApplication.ActiveDocument;
        #endregion
        #region Public Methods and Operators
        /// <summary>
        ///     The Execute.
        /// </summary>
        public void Execute()
            var pointId = this.civilDocument.CogoPoints.GetPointByPointNumber(5);
            using (
                var tr = this.acadDocument.TransactionManager.StartTransaction())
                var point = tr.GetObject(pointId, OpenMode.ForWrite) as CogoPoint;
                if (point != null)
                    point.RawDescription = "Test";
                tr.Commit();
        #endregion
joantopo
in reply to: zrobert
Yes, there are samples in API documentation:
CogoPointCollection cogoPoints=civDoc.CogoPoints;
ObjectId pointId=cogoPoints.GetPointByNumber(PointNumber);
CogoPoint CP=pointId.GetObject(openMode.ForRead) as CogoPoint;
double elevation=CP.Elevation;
I didn´t know that:
 is the same than:
CogoPointCollection cogoPoints=cogoPointCollection.GetCogoPoints(civDoc.CogoPoints);
And;
CogoPoint CP=pointId.GetOObject(openMode.ForRead)as CogoPoint;
is the same than:
                var CP= tr.GetObject(pointId, OpenMode.ForRead) as CogoPoint;
 thank you very much Robert.
Rail Community
