Ok I tried to use the code supp[lied here to keep autosave turned on for my work PC but it does not seem to work. I have attached a copy of the acaddoc.lsp file I use. All other commands seem to be set. This files path is on top of my AutoCAD Suuport Path listing in the Options dialog.
Could my issue be that the lsp file has two defun C: entries?
The best part of me debugging this is that my laptop is unaffected by the publish command & autosave stays on all the time...:o
John Mayo
Solved by jmayo-EE. Go to Solution.
I don't like giving myself solutions but based on recent emails I gues Autodesk likes closure. 😉
With that said I will provide my specific solution.
Again I had the SAVETIME set to load as a command not a sysvar and I had extra quotes.
In my lsp I had (command "SAVETIME "10") and I should have had this, (setvar "SAVETIME" 10).
John Mayo
