AddTinSurface Method
Message 1 of 13
Is there a bug in the current method to create a new TIN surface? I keep getting an error when the time comes to create the new surface object.
'AeccDB is set public already
'create the new tin surface (my engineered fill surface)
Dim surfs As AeccSurfaces
Dim efsurf As AeccSurface 'tin surface
Dim efdata As AeccTinCreationData
Set efdata = New AeccTinCreationData
efdata.name = "TestTIN"
efdata.Style = "Standard"
efdata.BaseLayer = "0"
efdata.Description = "Test"
efdata.Layer = "0"
Set surfs = AeccDb.Surfaces
Set efsurf = surfs.AddTinSurface(efdata)
It bugs out at the last line "Invalid procedure call or arguement"...
i have played with it long enough, Help?
-Jeff
Replies (12)
Message 2 of 13
Jeff,
I just tried this:
Option Explicit
Public g_oCivilApp As AeccApplication
Public g_oAeccDoc As AeccDocument
Public AeccDb As AeccDatabase
' Start Civil 3D and create Civil 3D document and database objects.
Function getCivilObjects() As Boolean
Dim oApp As AcadApplication
Set oApp = ThisDrawing.Application
Const sAppName = "AeccXUiLand.AeccApplication"
Set g_oCivilApp = oApp.GetInterfaceObject(sAppName)
If g_oCivilApp Is Nothing Then
MsgBox "Error creating " & sAppName & ", exit."
getCivilObjects = False
Exit Function
End If
Set g_oAeccDoc = g_oCivilApp.ActiveDocument
Set AeccDb = g_oAeccDoc.Database
getCivilObjects = True
efdata.Name = "TestTIN"
efdata.Layer = "0"
End Function
Works fine for me. I am running SP3.
Nick
wrote in message news:5384758@discussion.autodesk.com...
efdata.Layer = "0"
-Jeff
Message 3 of 13
Thanks Nick,
My code "looked" the same...and when I tried yours on my test drawing it bugged out again...good news! I just discovered that if the new surface "style" property (in this case it was called "standard" is not found in the current document the method cannot create the tin surface object...after I changed this to something that does exist (ie.._No Display) it worked fine,
Therefore, I will need to test for the style name before I assume that "standard" already exists, or populate a form/combo surface style list and have the user pick what they would like to have for the new surface style...
Thanks again
--Jeff
Message 4 of 13
Ah ya that is always a problem when creating objects thru vba. The style
you are using must exist. I have added the same check to a bunch of my
code.
Nick
wrote in message news:5388023@discussion.autodesk.com...
Thanks Nick,
Thanks again
--Jeff
Message 5 of 13
I'm not sure if it is possible to create a drawing with no "style", but
assuming it isn't, then you can use the Styles Collection item (0). It
should always exist.
In reality, it's better to check how styles exist with a select case
statement.
0 - report an error, or create a style and allow the user to customise it
later
1 use it
2 or more, have a standard form with a list box which you populate with the
available style and ask the suer to select one.
Regards
Laurie Comerford
www.cadapps.com.au
www.civil3dtools.com
"Nick Zeeben" wrote in message
news:5388213@discussion.autodesk.com...
code.
Nick
Thanks Nick,
Thanks again
--Jeff
Message 6 of 13
Thanks for the input Laurie/Nick,
As a final note, I was able to basically complete my task at hand (EngFill Volume Calculator) and I have to say that the combination of the API to create Volume Surfaces on the fly with Cut-Fill-Net Statistics with an applied Custom Surface Style to display results is amazing. I will be comparing my volumes with "old" Land Desktop methods today and I have my fingers crossed that the numbers are fine...
--Jeff
Message 7 of 13
DRossger
Hi Jeff!
I have exactly the same problem as you described. Did you get a solution or is it continue problem to create tinsurfaces externly ?!
Message 8 of 13
Civil3DReminders_com
Here is some code that I did a while ago.
    Private Function CreateEGSurface() As AeccLandLib.AeccTinSurface
        Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
        Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
        Dim trans As Autodesk.AutoCAD.DatabaseServices.Transaction = tm.StartTransaction()
        Try
            Dim oSurface As AeccLandLib.AeccTinSurface
            Dim oTinCreationData As New AeccLandLib.AeccTinCreationData
            ' Make sure the layer exists.
            Dim oLayer As LayerTableRecord
            Dim oLayerID As ObjectId = Nothing
            Dim oLayerTbl As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForRead, False)
            Dim sLayerName As String
            sLayerName = "EX-SRF-EG"
            If oLayerTbl.Has(sLayerName) = False Then
                ' Create a new layer table record.
                oLayer = New LayerTableRecord
                oLayer.Name = sLayerName
                oLayer.Color = Color.FromColorIndex(ColorMethod.ByAci, 9)
                oLayerTbl.UpgradeOpen()
                oLayerTbl.Add(oLayer)
                trans.AddNewlyCreatedDBObject(oLayer, True)
                oLayerTbl.DowngradeOpen()
            End If
            oTinCreationData.BaseLayer = sLayerName
            oTinCreationData.Description = "Existing Surface"
            ' Need to add code to make sure the surface layer exists, if not create it.
            oTinCreationData.Layer = sLayerName
            oTinCreationData.Name = "EG"
            ' Need to add code to make sure the style exists, if not create it.
            Dim i As Integer
            Dim bStyleExists As Boolean
            Dim sStyleName As String
            sStyleName = "Existing Surface Contours [Background]"
            bStyleExists = False
            Dim oCivil As New AeccAppConnection
            For i = 0 To oCivil.AeccDoc.SurfaceStyles.Count - 1
                If oCivil.AeccDoc.SurfaceStyles.Item(i).Name = sStyleName Then
                    bStyleExists = True
                    Exit For
                End If
            Next
            If bStyleExists = False Then
                ' Use first surface stye in the list.
                sStyleName = oCivil.AeccDoc.SurfaceStyles.Item(0).Name
            End If
            oTinCreationData.Style = sStyleName
            oSurface = oCivil.AeccDoc.Surfaces.AddTinSurface(oTinCreationData)
            trans.Commit() ' Keep the Changes
            Return oSurface
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            trans.Abort()
            Return Nothing
        Finally
            trans.Dispose() ' Done with transaction
        End Try
    End Function
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 9 of 13
DRossger
I didn´t find the class for AeccTinCreationData in C#.NET
        private TinSurface CreateEGSurface()
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
            Autodesk.AutoCAD.DatabaseServices.Transaction trans = tm.StartTransaction();
            try
                TinSurface oSurface = default(TinSurface);
                AeccTinCreationData oTinCreationData = new AeccLandLib.AeccTinCreationData();
                // Make sure the layer exists.
                LayerTableRecord oLayer = default(LayerTableRecord);
                ObjectId oLayerID = ObjectId.Null;
                LayerTable oLayerTbl = trans.GetObject(db.LayerTableId, OpenMode.ForRead, false);
                string sLayerName = null;
                sLayerName = "EX-SRF-EG";
                if (oLayerTbl.Has(sLayerName) == false)
                    // Create a new layer table record.
                    oLayer = new LayerTableRecord();
                    oLayer.Name = sLayerName;
                    oLayer.Color = Color.FromColorIndex(ColorMethod.ByAci, 9);
                    oLayerTbl.UpgradeOpen();
                    oLayerTbl.Add(oLayer);
                    trans.AddNewlyCreatedDBObject(oLayer, true);
                    oLayerTbl.DowngradeOpen();
                oTinCreationData.BaseLayer = sLayerName;
                oTinCreationData.Description = "Existing Surface";
                // Need to add code to make sure the surface layer exists, if not create it.
                oTinCreationData.Layer = sLayerName;
                oTinCreationData.Name = "EG";
                // Need to add code to make sure the style exists, if not create it.
                int i = 0;
                bool bStyleExists = false;
                string sStyleName = null;
                sStyleName = "Existing Surface Contours [Background]";
                AeccAppConnection oCivil = new AeccAppConnection();
                for (i = 0; i <= oCivil.AeccDoc.SurfaceStyles.Count - 1; i++)
                    if (oCivil.AeccDoc.SurfaceStyles.Item(i).Name == sStyleName)
                        bStyleExists = true;
                        break; // TODO: might not be correct. Was : Exit For
                if (bStyleExists == false)
                    // Use first surface stye in the list.
                    sStyleName = oCivil.AeccDoc.SurfaceStyles.Item(0).Name;
                oTinCreationData.Style = sStyleName;
                oSurface = oCivil.AeccDoc.Surfaces.AddTinSurface(oTinCreationData);
                trans.Commit();
                // Keep the Changes
                return oSurface;
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                trans.Abort();
                return null;
            finally
                trans.Dispose();
                // Done with transaction
Message 10 of 13
The thread was using COM so I provided that solution.
If you want to use .NET then check out this post: http://adndevblog.typepad.com/infrastructure/2014/01/creating-civil-3d-tin-surface-from-contours-pol...
Civil Reminders
Message 11 of 13
DRossger
The same problem with this code. I only want create a empty surface
using (Transaction m_Tr = db.TransactionManager.StartTransaction()) { try { m_SurfaceStyleId = civilDoc.Styles.SurfaceStyles["your style"]; m_SurfaceId = TinSurface.Create("TIN_Surface_From_Contours", m_SurfaceStyleId);
It have to work, but not for me, have I annother way to make it possible ?!
Message 12 of 13
Jeff_M
cadplayer, could you be a bit more specific? You say 'it doesn't work'...does it throw an error? If it is, and you aren't Catching it advise the user, the try will just bypass it. What version of C3D? Your first reply mentioned 'externly', are you trying to do this from a standalone application or from inside a running instance of C3D? Can you post your code that 'doesn't work'...or was that it a few replies back?
