I have added the references to my Vb.net Code but when i run the program the references are broken why it is happening.
can you describe (or show screenshots) what you mean by "references are broken"?
- alfred -
Sorry if i say something wrong because i am just new from Visual lisp to Vb.net
what i did is that i pasted one old code to visual studio 2010 and for refernces i just clicked add reference and saw in the recent tab all the eference are already there which i defined them for the previous project . How can i use them for the current project because when i go to recent tab and pressed ok the code is ok but when i run they are broken.
Have you selected one (or more) of the listed references or did you just open the dialog and closed it (without selecting anything to add)?
- alfred -
I selected all of them and than say ok , for timebeing it is ok but when i run F5 the refrences are broken.
can you show a screenshot with the references within your project?
- alfred -
I've seen this when the dll you reference are a later version of .NET than what your current project is set to support. For example your project is .NET 3.5 but you reference 4.0 dlls.
OK than what is the solution to this.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/NET-Framework-4/m-p/4961100#M8982
