Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
API: How can I delete all breakline sets included in definition off Surface?
3 REPLIES 3
joantopo
442 Views, 3 Replies
I want delete all breakline sets of one selected surface using API.
There is "SurfaceOperationAddBreakline" but I don´t find "SurfaceOperationDeleteSetBreakline" for example.
Is there other way to delete all breakline sets of one surface?
Later, I want to create one set breakline for each layer which has been selected by user.
I know that I can use qselect, but I want do this process automatically.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
joantopo
in reply to: joantopo
Perhaps it is "SurfaceOperationCollection" method Remove or RemoveAt()
Partha.Sarkar
Try this -
http://adndevblog.typepad.com/infrastructure/2013/09/removing-surface-breaklines-using-autocad-civil...
Let me know if you need any further help here.
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
joantopo
in reply to: Partha.Sarkar
Hi Partha.
 I haven´t seen that link before.It´s great!.
However,I don´understand "surfaceId". How I put Id surface to refer the surface?
Thank you.
Rail Community
