2012 Subassembly do not connect to the new Assembly I am creating
Message 1 of 1
Background:
In this drawing this use to work.  In a new drawing this works but, I don't want to start all over.
Here is what is happening:
  1) I create a new assembly. (Three others reside in this drawing.)
  2) From the tool palette I select a subassembly to add (I have tried many of them)
  3) I select the assembly I just created.
     Results: ... Nothing... Subassembly does not appear.
  4) I select again
  5) I right click.
  6) I select again
  8) I insert the subassembly to an open area
     Results: Subassembly is inserted.
  9) I select and try to move the subassembly to the assembly.
     Results:  Subassembly does not attached to the assembly.
 10) I check the assembly properties.
     Results: No subassembly is listed as being attached to the assembly.
Has a setting been changed? If so which one?
Replies (0)
