• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Member
    sizes in door schedules
    77 Views, 6 Replies
    02-12-2013 11:17 AM
    i have created a door schedule and it seems to be missing the most important part, the sizes!  When I go into Style Manager and click on the door shcedule and try to add columns size does NOT come up as a choice.  I have added size to the property sets of the doors.  This is driving me crazy as I have tried everything I can remember from  older versions of Autocad and it just won't put in this bit of information.  Please help.
    Please use plain text.
    Valued Mentor
    leothebuilder
    Re: sizes in door schedules
    02-12-2013 01:58 PM in reply to: cpwsjs
    Are the property set definitions in your drawing file ?
    The DoorObjects p.s.d typically has the door size.
    Or do you have a customized door p.s.d. ?
    Active Member
    02-12-2013 02:10 PM in reply to: leothebuilder
    Yes, they are in my floor plan drawing, I do not have a seperate file for the property set definitions.
    02-12-2013 02:43 PM in reply to: cpwsjs
    Create a sample file with a few Doors, set up the way you expect to work, with the Property Sets and Schedule Table Style that you have developed.  ZIP it up and post it to a reply here, so we can see what you have done so far and determine what needs to be done.
    David Koch
    Valued Contributor
    02-12-2013 05:05 PM in reply to: cpwsjs
    This may not be your issue but if you're scheduling from a file separate from the file containing the doors as it sounds, and the property set in your file containing the doors has been updated (to show sizes for instance), that won't automatically update the property set in the file containing the schedule.  You'll need to update the property set in that file separately.
    John
    John W. Mumaw
    Timber Frame Designer
    Lost Bent Woodworking & Design
    Active Member
    02-13-2013 06:05 AM in reply to: John.W.Mumaw
    No, its all in one file right now, that's why I don't understand it.  But I will try making a seperate file to show here.
    Active Member
    02-13-2013 08:55 AM in reply to: cpwsjs
    Now, somehow my door schedule disappeared and when I try to make a new one nothing shows up.
