Good Day to all,
I am running in to a problem when creating tables in Autocad Architecture 2012. The problem occures when the table size has increased, for example, I recently created a "Room Finish Schedule" table and it is 11 columns by 200 rows. When selecting a cell to edit, selecting the table itself, or to make any modifications once the table is selected takes a bit of time for the action to be exccuted. Is there any way to speed the process or improve the tables. I am not sure if creating two different tables rather than one would work better. I am trying to avoid using Excell sheets that are pasted into CAD becasue of OLE issues I've run into in the past.
Thank you for your time,
Raman.
it is a regular table. I guess you can say an autocad table, but the software being used is autocad architecture. we did not want to make a smart schedule, because it would just be used to input finishes within a space.
Others will have to jump in here, as I have very limited experience with AutoCAD Tables. You may also want to post your question in the AutoCAD 2010/2011/2012 DWG Format Discussion Group, as you may find a larger pool of people there with AutoCAD Table experience.
