• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Member
    plot to file naming options
    79 Views, 1 Replies
    05-31-2011 08:10 AM
    Is there an option to eliminate AutoCAD from automatically inserting the layout tab name into the file name when creating a PDF?  Once upon a time it would only use the file name (i.e. A-101).  Now it uses "A-101_Layout1" (or whatever the layout name is) by default.  I either have to live with it or manually change each file name during the process of creating the PDF or after it's been created.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: plot to file naming options
    05-31-2011 09:20 AM in reply to: mblackledge
    I suspect you had a customization that did that for you (or pre-Layouts AutoCAD?): tab names are the default behavior (and work great for us as it is part of the file name/content).
    I believe you can turn off auto-naming altogether with FULLPLOTPATH variable set to 0 (zero).
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
