• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Active Member
    Accepted Solution
    freezing layers in xrefs within Viewports
    208 Views, 2 Replies
    02-21-2011 11:36 PM
    I have an xrefernced drg , which i print from a layout/paperspace .I freeze certain layers using VPort freeze in layer properties and save the drg whenever i close and reopen the drawing the layers are thawed in the viewport again.
    Where am i going wrong? Can someone help .
    ****Sage
    Re: freezing layers in xrefs within Viewports
    02-22-2011 04:59 AM in reply to: AndrewPM1975
    VISRETAIN setting perhaps, if the problem is strictly limited to XREFs?
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    02-04-2012 07:39 PM in reply to: pendean
    I am having the same problem.  I cannot get the Drawing to retain the modified layer properties.  There are some layers I want to turn off in the viewport.....I freeze them as soon as I close the drawing and repoen it, they reapear!!  I have tried VISRETAIN set to 1......
    ...please help!
