• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture Customization
    Active Member
    expanding automatic property sets of doors
    108 Views, 2 Replies
    03-28-2002 11:35 PM
    I am looking for help in adding automatic property sets to those already defined for doors. Our office does nothing but schools, and we have boiled our door types down to about 15 assemblies that we use most frequently. Since ALL of these sets receive the same finish, same hardware, etc., we would like to develop a door symbol (aec content) that includes all of this information, so that all we have to do to create a door schedule for an opening is pick the correct assembly type. The door size, material, finish, frame type, material, finish, head detail#, jamb detail#, sill detail#, and rating would ALL be contained in that smart symbol, and entered across the schedule automatically.
    I understand property sets, custom AEC tags, etc., but cannot seem to embed the properties mentioned above into a door and have it report automatically. I can create them and have them be manually edited, but since all of our doors have been highly standardized, we'd like to standardize the door schedule reporting too.
    I've tried creating attribute definitions, multi-view doors, block doors, and profile based doors, but no luck.
    Does anyone have any ideas on how to embed these values in an AEC Door content?
    Please use plain text.
    *M, Nauman
    Re: expanding automatic property sets of doors
    03-29-2002 02:29 AM in reply to: dore
    Have you tried Style based property sets? I assume you are using ADT3?
    then have the 15 doors as different doors, Door St1 Door St2 what ever.
    and then have stylebased property sets attached to the style, in the
    style editor there is a button under general tab called property sets.
    this might be a way to go..
    > automatically.
    > content?
    Nauman M
    CAD Bazaar
    *********NEW*********
    Add AEC Objects to the Layers(lkey) you want, not the Layers ADT Wants!!
    Add a Wall directly on the DEMO Layerkey, instead of switching it later.
    Download the eval at http://www.cadbazaar.com
    Need to easily Navigate to your Custom Content Folders?
    Need Autolayering for Dimensions without going through Design Center?
    Download the ADT Tools for ADT 2 & 3 at
    Active Member
    Re:
    03-29-2002 06:06 AM in reply to: dore
    Actually, We're still on Release 2. Is this different than what one can do with the door styles under 2i? I've tried using different styles as a basis, but cannot get automatic properties, just manually edited ones....
    I'll have to check this out.
