AutoCAD Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
.dwg to .pdf = Fatal error
- Highlight
- Email to a Friend
- Report Inappropriate Content
To be more precise:
fatal error unhandled access violation writing 0x0024 Exception at 7776e4b4h
I've set up a drop down menu with various page setups coming from another file (-psetupin).
If I initiate a page setup for our Plotter or Printer, everything works fine. If I initiate a page setup for the 'dwg to pdf.pc3', I get the error listed above. I don't understand why, it worked fine not too long ago. Also, if I manually create a page setup with the same 'dwg to pdf.pc3' it works fine...
Anyone has an idea as to why this happens?
Cheers
ACA 2012
Windows 7
Intel Core i7-2600 CPU
3.4GHz - 8GB ram - 64 bit
Re: .dwg to .pdf = Fatal error
- Highlight
- Email to a Friend
More developments: I think I've found the problem.
I think my 'dwg to pdf.pc3 might have been corrupted. I replaced it with the ootb 'dwg to pdf.pc3' and it seems to work now. I had created Custom Paper Sizes in the old 'dwg to pdf.pc3' and I believe that might have done it.
Now the only problem left is to figure out how to get the paper sizes we want to use.
ACA 2012
Windows 7
- Highlight
- Email to a Friend
In this case I have uploaded/attached a copy of our stock “DWGtoPDF” driver for use and review. Additionally, you mentioned that you were looking to included additional paper sizes to this driver. To add additional sizes you will need to create custom paper sizes for your none standard sizes for this plot driver.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
I just wanted to check back in and se if there was anything further we could help with on this inquiry. Please let us know if further assistance is needed in the community and if not please let us know so we and/or you can mark this post as solved. Thank you and we look forward to your update.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Thanks for checking up
It's been working on and off for a while, but I've put that issue aside for now in order to fix other things.
I'll take a little more time to try and figure out what's causing the problems.
As soon I figure it out, I'll let you know.
Cheers
Pierre P.
ACA 2012
Windows 7
- Highlight
- Email to a Friend
Thank you for your reply. Please keep us posted in the community and if it should occur again please post back and let us all know so members can help contribute towards possible resolutions. Thank you.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
