• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture
    Member
    avengineering
    civil 3d contours in arch 2009
    64 Views, 3 Replies
    02-03-2012 05:12 PM
    I have 2009 Architecture 64 bit installed and want to view pre 2009 contour objects.  I went to the enablers site and noticed the only enabler for civil 2009 is a 32 bit and am unable to install the enabler.  Am I installing the wrong enabler?  Seems there should be a way for these to be imported. The contours were created in 2002 LDD. Do I need to have the contours converted to plines?
    Robert
    ****Sage
    Re: civil 3d contours in arch 2009
    02-04-2012 03:47 PM in reply to: avengineering
    There are no extra OEs from any other location: in 2009, -EXPORTTOAUTOCAD does a decent job of converting most AEC objects to their basic entities. But be aware it will do the same to all of your ACA2009 objects in the file too: so separate the Civil content first.
    AFAIK there is no ACA2009 64bit version: you just can't install 32bit OEs in Windows 64bit.
    Please mark any response as "Accept as Solution" if it answers your question.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    RSS: http://ltisacad.blogspot.com/feeds/posts/default
    Twitter: http://twitter.com/LTisACAD
    Pinterest: http://pinterest.com/pendeaninc/pins/
    Member
    avengineering
    02-08-2012 10:19 AM in reply to: avengineering
    Thank you for the work around. I'll give it a shot. BTW ACA2009 has a 64 bit disk. I made the assumption Civil3d would also..why not??
    Robert
    MarySeufert
    02-09-2012 09:45 AM in reply to: avengineering
    Civil3D didn't have a 64bit release until 2011.
    ~ Mary
