I would test another Windows user account on this same machine, one who has never logged onto this computer before, and see if the behavior exists there. This way you can narrow it down a bit. If it doesn’t happen for the other user then chances are there is a setting amiss or a problem in the install as it pertains to the Windows user account and interface with AutoCAD.
You could try a repair but if it only happens for the one user this more than likely will not help. You may have to reset ACA back to default by initiating the secondary installer.
Issue
To reset the default AutoCAD® Architecture 2012 user settings, you want to reinitiate the secondary installer.
Solution
To reset the AutoCAD® Architecture 2012 default user settings, you must first delete your application files and registry entries for the program. Follow these steps:
Note: Make sure that you back up any customized AutoCAD Architecture 2012 files before starting this procedure.
1. Click Start menu (Windows) > Run.
2. In the Run dialog box, enter regedit
3. In the Registry Editor, browse to the following subkey and delete it:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A004:409
4. Close the Registry Editor.
5. Using Windows Explorer, browse to and delete the following user's application folders:
Windows 7
C:\Users\<user>\AppData\Roaming\Autodesk\ACA 2012
C:\Users\<user>\AppData\Local\Autodesk\ACA 2012
Windows XP
C:\Documents and Settings\<user name>\Application Data\Autodesk\ACA 2012
C:\Documents and Settings\<user name>\Local Settings\Application Data\Autodesk\ACA 2012
6. Start AutoCAD Architecture 2012. This will initiate the secondary installer, recreating the deleted files and folders.
Warning! Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined for your operating system in the Microsoft Knowledge Base and in the related solution, TS66513. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Lance Edwards
Product Support Technical Specialist
Product Support
