I was asking on how to gain access to the aecdatabase via vlisp-activeX:
sorry i was not clear there. the routine was posted as an example only ,
that I can access properties of selected objects, but how to pull from
database , like the scale, etc. was not looking for the translation in
VBA..
more so the translation from VBA to VLISP..
of
Public Sub PrefAccess()
Dim doc As New AecArchBaseDocument
Dim Pref As AecArchBaseDatabasePreferences
doc.Init ThisDrawing
Set doc = AecArchBaseApplication.ActiveDocument
Set Pref = doc.Preferences
Pref.DatabaseScale = 192
Pref.OLELaunch = True
End Sub
thanks
Rob Starz wrote:
> First Nauman you posted a different code than what you were asking for. I
> will answer both.
> as per you lisp code here is the VBA code
> Public Sub GetObj()
> Dim objTemp As AcadEntity
> Dim objUtil As AcadUtility
> Dim varPnt As Variant
> Dim Wall As AecWall
> ThisDrawing.Utility.GetEntity objTemp, varPnt, "Select Object"
> If TypeOf objTemp Is AecWall Then
> Set Wall = objTemp
> Wall.CleanupRadius = 60 'changes cleanupradius to 60
> 'set a break at this point and then do a watch on WALL
> 'You will see all available settings
> 'before you go setting stylenames check
> 'to see if they exist in the dwg
> End If
> End Sub
> as per the database code
> End Sub
> Rob Starz
> Plogv 3.0 & 2000 (plot logging) for r14 & 2000
> ***Enhancement Tools for Arch. Desktop *****
> !!!!!Beta Testers Needed For DormerX!!!!!!!
> http://www.stardsign.com/DormerXForm.htm
> http://www.stardsign.com/main.htm
Nauman M
CAD Bazaar
Need to easily Navigate to your Custom Content Folders?
Need Autolayering for Dimensions without going through Design Center?
Download the updated ADT Tools for ADT 2 & 3 at
http://www.cadbazaar.com
