you stepped on something that I think it was Terry or Frank , boy they
were mad regardig this issue.
any case the xrecords are easily accessible via lisp. HoW? have no clue
as how to do it, but go to Autocad.customization group and there are
many routines posted to read/write xrecords. I think the website will
give you tools for the search. Basically you will see them in two
flavors, ActiveX and plain old lisp, I believe both work the same..
once u figure out the translation code, you can run a script on the
files, the ScriptPro used to come with xpress tools, then I think they
merged it with migration tools, and then now with 3.3 you have to
download the migration tools from adesk website, considering it being a
5 meg file, why they did not include it on the CD, is beyond me.
PS: avoid going back n forth between r14 and adt3.3, you are askinig
for trouble with your files...
Peter Theis wrote:
> Now I'm in trouble. It appears that Xrecords are VBA - any tips on how to
> access xrecords for the Visual Lisp programer's point of view? I've yet to
> tackle the VBA thing...
> Also - are you sure that this isn't stored in the same way (IE- are you sure
> this will make the acad version transition?
> Thanks,
> -Peter
> Terry W. Dotson wrote in message
> news:3B71D061.649A70A3@dotsoft.com...
> > Peter Theis wrote:
> > > Part of the application writes a small but critical amount of
> information to
> > > the drawing dictionary via VLAX-LDATA-PUT.
> > Bad news. The data is bound the R14 ARX and you can't get to it from
> > 2000+.
> > IMO you will have to open each drawing in R14 and transition the data
> > through an xrecord.
> > Good Luck, Terry
> > o--------------------------------------------------o
> > | Never start any job without the right tools! |
> > | AutoCAD Add-on Tools at http://www.dotsoft.com |
Nauman M
CAD Bazaar
Need to easily Navigate to your Custom Content Folders?
Need Autolayering for Dimensions without going through Design Center?
Download the updated ADT Tools for ADT 2 & 3 at
http://www.cadbazaar.com
