If its a multiviewblock like a door tag or room tag then you'll want to access the schedule data associated with the door or space respectively. You can download the attached vba macro RoomZoom2.
RoomZoom2 displays a userform with a textbox and a command button. When you enter a Room or Space Number and click the "Find" button, it will cycle through all the available space/room objects in the current drawing and any attached xref and zoom your display to center on that space.
Take a look at the code within the macro to see how to:
----- use the acfocus control (allows you to keep the form visible on the screen while you interact with entities within your file.
----- find the schedule property and get the associated object.
Hope that helps,
Richard Binning
P.S. The password for the macro is "AUGI" without the quotes.
Join AUGI.
