- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I purchased VisionRez several years ago, but only installed it late last summer (current version of ACA and current version of VR). After working with it for several weeks, I mostly stopped using it, but for a while would go back and grab one of their tools for a drawing. About a week ago, I uninstalled it, and am now in purgatory for all the sins I've committed in my life. Over a period of several months, I propagated VR objects in new drawings by copying and pasting parts of drawings into new ones. I had no hint of a problem until I uninstalled the product (for which I do have a paid license with subscription). If I attempt to copy and paste, I get a Copy to clipboard error message. I get one error message per session, then abort. Every clipboard error requires a new restore of the drawing unless I immediately close the drawing. VisionRez support claims that it is an error "native to the AutoCAD Architecture (since early 2007) and not VisionRez. " Support suggested several "workarounds", none of which work, for example, blocking the entire drawing into a new one and then exploding it. The block shows up in the Design Center folder, but does not appear in the Insert dialog box. I have managed to remove all VR objects from one single drawing (or at least I no longer receive the copy to clipboard error), but that took several hours of pure agony. This morning's frustration is attempting to retrieve a complex bathroom vanity from one of these drawings. I cannot bring it into a new drawing, even though it was not created with any VR objects. I can copy and paste it without errors, but the cabinet doors and parts scatter all across the new drawing. I can block it first, but with the same results as when I block the entire drawing--it doesn't appear in the drop down list of the Insert dialog box in Design Center. I just want to purge/remove every frigging VR object from these drawings, and VR claims to have no way to do this (and asked if I would consider reinstalling the product). Does anyone know of any way to purge objects that are in a drawing without first manually deleting them one by one?
