• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Architecture Customization
    Valued Mentor
    Accepted Solution
    Two 'Graphic Property Definitions' set by formula property.
    120 Views, 3 Replies
    02-12-2013 02:07 PM
    Is there a way to control which of two 'Graphic Property definitions' are used via a formula property with a IF, Then, condition statement?
    Please use plain text.
    *Expert Elite*
    Re: Two 'Graphic Property Definitions' set by formula property.
    02-12-2013 02:15 PM in reply to: mdhutchinson
    Not so far as I know.
    David Koch
    Valued Mentor
    02-12-2013 03:00 PM in reply to: David_W._Koch
    Yeh, that's what I am seeing.
    See this:
    http://www.jtbworld.com/images/adt2007schedule.gif
    How is the image getting switched up?
    *Expert Elite*
    02-14-2013 03:58 PM in reply to: mdhutchinson
    While you can set a default image in the Property Set Definition, you need to assign the image associated with a specific instance (for an object-based PSD) or style (for a style-based PSD).  The Schedule Table will show the image associated with the object(s) on a particular row.
    David Koch
