• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture Visualization
    Sun settings
    994 Views, 10 Replies
    11-03-2010 08:52 AM
    What is the difference of the Intensity factor in General and Sky Properties? I'm trying to get a mild sunshine coming through the windows in a interior of a room scene, but can not get it right. Also is there a way to make the walls look straight in a wide angle view?
    Thank you for your help.
    Please use plain text.
    Valued Mentor
    Re: Sun settings
    11-03-2010 12:54 PM in reply to: Pat_03
    I really like the way it looks as is--the amount of sun coming in is very nice, and the perspective looks right.   What are your render settings (sun intensity, sky & illum., etc.)?
    Active Member
    clairecarter
    Re: Sun settings
    02-13-2011 06:49 AM in reply to: KathyMoffa
    i have a problem i hope someone can help..
    am trying to turn on sky but it will not let me..
    when i turn the sun on  there is no light, the time is correct, the lighting units are set to photometric
    anyone has a clue?
    thanks
    claire
    Valued Mentor
    Re: Sun settings
    02-14-2011 07:27 AM in reply to: Pat_03
    Switch from a parallel to perspective view, and you will be able to turn on the sky.   I am not sure what's going on with your sun setting, but one thing to look at is your geographic location and what direction you are facing in your drawing.    Take a look at what happens when you change the direction.
    Active Member
    clairecarter
    Re: Sun settings
    02-15-2011 12:14 AM in reply to: Pat_03
    Hi thanks for your reply , am trying to turn perspective on but it keeps on turning off as soon ad i press apply...
    any clue why?
    thanks
    claire
    Valued Mentor
    Re: Sun settings
    02-15-2011 04:08 AM in reply to: clairecarter
    How are you getting into Perspective?   Try right clicking, select 3D Orbit, then immediately right click again and check Perspective.
    Active Member
    clairecarter
    Re: Sun settings
    02-15-2011 06:00 AM in reply to: KathyMoffa
    hi i tried that too but sky is still off....perspective box is checked when i right click...
    Valued Mentor
    Re: Sun settings
    02-15-2011 07:14 AM in reply to: clairecarter
    Can you post the drawing?
    Active Member
    clairecarter
    Re: Sun settings
    02-15-2011 10:23 AM in reply to: KathyMoffa
    hi, somehw i managed to turn it on...but all the images are hazy... i tried posting but file too big...
    c
    Active Member
    StudyParticipant-3747
    Re: Sun settings
    03-29-2011 10:26 AM in reply to: clairecarter
    Have the same problem - if nothnig works I just purge drawing and copy all the stuff (or only 3D ojects)  to new dawing (good old CTR/C & CTR/V)  to make sun work (sky and syn becoms "clicable" )
