AutoCAD Architecture Customization
Hugh_Compton
Message 1 of 2 (195 Views)
Structural Member - Elevation Tag
195 Views, 1 Replies
03-11-2013 09:41 AM
Hello
I've attached a structural member.  Is it possible to tag each end individually and have ACA report if it's the high end or low end of the structural member?  Please see the file for further explanation.
Keith.Brown
Message 2 of 2 (182 Views)
Re: Structural Member - Elevation Tag
03-12-2013 02:45 PM in reply to: Hugh_Compton
It is possible to tag the elevation of the high end and the elevation of the low end but autocad architecture cannot make the distinction of which end is which.  The same situation applies for tagging the elevation of sloped pipe.
You can create two tags called startend and lowend.  The start end would compare the elevation of the start end with the elevation of the end and it is is higher then it can say higher or if it is lower then it would say lower.  The same goes true for the other side.  You would just need to always tag the startend tag at the begining of the structural member.  This is made easier by the block that you have added to the member symolizing direction.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
You are not logged in.
Ask the Community
