AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Script question
1 REPLY 1
Logos_Atum
267 Views, 1 Reply
Script question
Hello there,
I´m trying to write a script to convert all the blocks in a drawing to mass elements
and export them to IGES thereafter.
I would like to select everything first. Then launch refedit and select all the blocks.
Aftaer that I would like to convert them to mass elements. When saving to IGES I
would need to select everything again.
I pieced the following script together, but it fails. I think it is bexause of the request to
select objects manually. Could I add a delay which would enable me to select an object?
Also it looks like ACADA is not accepting the "all" command when pselect is called by a
script.
PICKFIRST 1
select
All
efedit
OK
A
N
_AecMassElementConvert
ALL
_REFCLOSE
_SAV
_EXPORT
all
Any help is greatly appreciated
Kind regards
Daniel
Dogs aren´t flammable.
1 REPLY 1
Logos_Atum
in reply to: Logos_Atum
Hello there,
perhaps I will switch to a macro. This would rule out the
user input issue and I could integrate it in the UI I guess.
Kind regards
Daniel
”Boost
