• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Architecture
    Member
    Schedule accuracy
    104 Views, 2 Replies
    11-24-2011 04:39 AM
    Hey all,
    Sorry for my english but :
    I use Autocad Architecure since ADT 2006. And I use a lot of Schedule Board to calculate area.
    I have a problem that I can solve :  when i ask to have SUM (total) of area i bad result some time like :
    33.35
    26.75
    45.89
    6.00
    7.33
    119.33 or sum i s 119.32.
    I've got this because ARCHITECTURE calculate with decimal precision of area space. I've understand it, but to have a solution to show schedule with 2 digits but want to have good result.
    I've tried to create new Property in my style Space with this formula which can give me Round Up of BaseArea... but noway : I can't have a good result.
    Is there anyone her who solve this problem ?
    thank you and sorry again for my poor langage.
    Mickaël
    *Pro
    Re: Schedule accuracy
    11-24-2011 06:41 AM in reply to: mickymx
    The problem you are having is that ACA uses the raw number, not the formatted/rounded number, when calculating the total of a Column in a Schedule Table, and then applies the format to that number.  Sometimes you get lucky, and the final number is the sum of the listed, rounded values; sometimes you do not get lucky and there is a variance.
    There is a way around this.  Instead of scheduling the automatic Area property directly, you can set up a Formula property that either does the rounding (if you cannot achieve your desired rounding with a Property Data Format) or that passes through the rounded value.  In the latter case, you will want to have a Property Data Format that does the rounding, but does not add any text to the result (like " SF" or " m2").  You can apply the "area" formatting, with text, to the Formula property, to get the " SF" or " m2" suffix in the Schedule Table.
    This blog article discusses using a formula property to get ACA to use the rounded value in the Schedule Table.  The example in the blog article was geared toward getting a Schedule Table with a Quantity Column to treat identical rounded values as the same, even when the source values were slightly different.  The same techniques will work to make ACA use the rounded value when calculating the sum of a Column.
    I will try to find time to put together a sample file that illustrates the two techniques and post it here.
    *Pro
    11-25-2011 07:07 PM in reply to: David_W._Koch
    Here is the sample file.  I also posted an article to my blog that goes into more detail about the formula properties in the sample file.
