Stuart,
So which bit are you having trouble with?
What have you attempted so far?
Dean
STU @ GGA wrote in message
news:EAFDBD095A1410FC62854E54CDA15C68@in.WebX.maYIadrTaRb...
> Okay, here's a pretty specific one I would really appreciate some help
with:
> I have an image tile menu set up for typical blocks we use in ACAD 2002.
We
> have also changed our layer standards to be strictly AIA. I am trying to
> set our library up to perform the following:
> -Through an image tile menu you select a block.
> -The routine calls a lisp routine that remembers the current layer you are
> on.
> -Inserts the block, "TUB.DWG," into the drawing from:
> "G:\CAD\BLOCKS\TUB.DWG."
> -Block is placed on layer "A-FLOR-PFIX" with color "11."
> -Checks the drawing for any other occurrence of the same block: "TUB.DWG,"
> and redefines it.
> -Checks for whether or not the former layer we used: "PLUMB," is in the
> drawing, and renames it to: "A-FLOR-PFIX" if it exists.
> -Sets back to the layer you were on.
> Thank you,
> -STU
